Online: Trunksie
G'day n that
  • Iron_883
    Iron_883
    7 years ago
    From Newcastle, new to Road Bikes and Harley's. Jumped in Feb this year, yeah it's a 2018 Iron. A good bike for short A's like me..
    I came here looking for a solution to a slight problem I have with my "odometer gear position number" which has disappeared since a recent service. I suspect the Clutch Cable has been adjusted without any free play in the Cable. Which slightly Disengages the clutch, not good for the Clutch but also cancels out the "odometer gear position number' (The number normally disappears when the Clutch is pulled in).
    Anyway, keep looking.
  • Omzz48
    Omzz48
    7 years ago
    welcome mate! that happened to my old iron as well when I had the clutched adjusted at the last service, didn't look into fixing it because I sold it, someone will help you out :)
  • Iron_883
    Iron_883
    7 years ago
    Quoting Omzz48 on 14 Aug 2018 02:04 AM
    Thanks Mate, that's encouraging. I adjusted it last night and will take it for a ride this arvo to test my theory
  • Iron_883
    Iron_883
    7 years ago
    Quoting Iron_883 on 13 Aug 2018 11:21 PM
    Well I adjusted the Clutch Cable, gave it about 2mm free play. Got 1st gear indicator working but the other gears are a no show. Adjusted some more both ways and lost everything again... must be touchy, can't find anything online on how to adjust.
  • brucefxdl
    brucefxdl
    7 years ago
    welcome iron,enjoy your time here,lots to see and learn.
    2 things to my thinking.....2018 should be under warranty.
    if this fault occured after service its a repair/adjust fault .
    i'd be back having a chat with the dealer.cheers
  • Iron_883
    Iron_883
    7 years ago
    Quoting brucefxdl on 14 Aug 2018 07:46 AM
    Thanks mate, normally I would, but where I bought it is 250k away....
    7 years ago
    Welcome Iron 883, last I checked can adjust clutch at the clutch centre of pressure plate, but can also do minor adjustment via cable bottom of frame primary side, think 9/16" & 1/2" open spanners  ( or two 1/2" as they lock adjustment ) not hard I do mine as like it set a bit different. just make sure some free play in cable. with gear counter? I've never had a Harley with one so can't say. enjoy your new ride!!
  • Iron_883
    Iron_883
    7 years ago
    Quoting Krash Kinkade on 14 Aug 2018 09:59 AM
    Thanks Krash, yes that's right 1/2" & 9/16" spanners.. I had a bit of a muck around. Also saw on youtube where you should have between 1/16" & 1/8" (1.5mm to 3.0mm) free play measured at the lever. Got the number indicator to respond.. 1st came back... so I think it is something in the adjustment.
  • Muzza Wa
    Muzza Wa
    7 years ago
  • Iron_883
    Iron_883
    7 years ago
    Quoting Muzza Wa on 14 Aug 2018 03:56 PM
    Thanks Muzza
  • imoo6170
    imoo6170
    7 years ago
    Welcome to the forum. I would be taking it back to the dealer to get it fully checked out
  • Iron_883
    Iron_883
    7 years ago
    Quoting imoo6170 on 14 Aug 2018 09:26 PM
    Thanks imoo, I should have bought local... live and learn. I normally would but it's a big operation getting it back up there on a weekend leaving it a week and bringing it back...
  • Humbug
    Humbug
    7 years ago
    Welcome, hope you enjoy your time here.
  • Wideglider
    Wideglider
    7 years ago
    Quoting Iron_883 on 14 Aug 2018 09:33 PM
    Welcome to the forum - a wealth of info on here & a good laugh also.
    You mention leaving your bike with dealer a week? Would have thought they'd fix it on the spot once you've pre-arranged it? Nice 250k's ride up, have a pub lunch while they adjust it, nice ride back home in time for dinner.
  • Iron_883
    Iron_883
    7 years ago
    Quoting Wideglider on 15 Aug 2018 02:32 AM
    Thanks Wideglider, sounds good mate... if they worked weekends...
    I just spoke with ol'mate the Mechainc. He is blaming the Stage 1 upgrade tuning... They might need it a week to sort it out:)
  • Iron_883
    Iron_883
    7 years ago
    Quoting Humbug on 15 Aug 2018 12:26 AM
    Thanks mate :)
    7 years ago
    Iron , has the dealer got a Dyno? But doubt they would custom map. still dyno good way to check the update ( what ever changes that has made ).
    Just went back re read your post. not a tuning issue so no worries. I've never owned a bike that told me what gear I'm in, one down & four up, but I love one up four down. I might put a shift leaver from Sputh that fits on the spline backwards so it goes over derby cover, have to mount a braket to hold foot peg at rear of primary. sorry for raving on. I would not worry too much about that problem. as not going to hurt the bike. could not see it taking long to fix.
  • Iron_883
    Iron_883
    7 years ago
    Quoting Krash Kinkade on 15 Aug 2018 04:51 AM
    I know mate, never had a bike with it either. Got a bit used to it, I suppose... I might be a bit ocd about it :)
