LED Light Bar
LED Light Bar
Wideglider
7 years ago
Anyone fitted an LED light bar between forks? So many on the market so want to sort out the crap from the robust. Looking for a compact, slimline type to fit to '96 WG.
STEAMER
7 years ago
LoftyBob has on a couple bikes
Fat Tom
7 years ago
I put this one on my fatboy. Any extra light is good light at night where I ride to work. I think by memory around $200 supplied and fitted
steelo
7 years ago
That looks great FT. Where did you get them from. Are they hoglights headlights as well?
LOFTYBOB
7 years ago
10 " Aurora on the crash bars, they make a 6" as well.
Bloody awesome light
Fat Tom
7 years ago
Quoting steelo on 31 Jul 2018 02:19 AM
got the light bar from the local auto sparky and yes they are hoglights best upgrade without a doubt
Wideglider
7 years ago
Thanks Steamer, Fat Tom, Lofty.
The Aurora LED bar looks just what I need, 6" should do the trick. Would sit nicely up under headlight between the forks.
