Online: Merv, Hidiho
96 cube 2011 softail. Fitting heads with ACR
  • Beads
    Beads
    7 years ago
    Hi all. I'm in the process of fitting a stage 3 103 kit to my 2011 softail. The kit has come with 103 heads with auto compression release holes drilled into them.
    My questions are:
    1. Has anyone on here fitted the ACR to a 2011 96 cube? Does the wiring harness have an allowance for it?
    2. Is there a "plug" available to block the holes temporarily so i can get the bike back on the road and fit the ACR at a later date?
    Thanks for your input!
    Beads
    7 years ago
    Quoting Beads on 25 Jul 2018 09:50 PM
    My questions are:
    Beads
    Beads not sure of the answer to question 1 but i believe you are able to fit manual ACR rather than blocking the holes as you mentioned
  • Beads
    Beads
    7 years ago
    Thanks pauly.
    I thought about that but the holes that have been drilled in the heads are right in the middle of the head which wont be accesible once the rockers and covers etc go on.
    7 years ago
    They aren't expensive, fit them now, otherwise a pain to remove the rocker box later.
    Most dealers should have them in stock.
    Note, you need a special socket to fit them.
  • Beads
    Beads
    7 years ago
    Quoting speedzter on 25 Jul 2018 10:28 PMedited: 25 Jul 2018 10:31 PM
    Cheers mate,
     Yeah ill fit them now. Do you know if the wiring is plug and play or a bit more involved?
    Is the special socket because of the harness that come out of the release?
    Cheers Beads
    7 years ago
    yes, the socket needs a cutaway for the wires. I made my own out of a deep socket.
    I'm not totally sure about the wiring, bit I do know there is a wiring harness kit available.
  • Beads
    Beads
    7 years ago
    Thanks for the help mate. I think i have it all sorted.
    Beads
  • KiwiRob
    KiwiRob
    7 years ago
    70623-06 is the part number you want for the ACR wiring harness. Google -J04210 for the instruction sheet. I think HD have a plug for plugging the holes if you don't want to fiddle with the harness install. I used manual compression releases on my engine, but hey were a pain in the arse so I changed to S&S easy start cams. That limits your cam choices though but the easy start feature is brilliant. - Rob
