Online: Merv, Hidiho
Wiring twin headlights
  • Mr.Mow
    Mr.Mow
    7 years ago
    So I’m thinking of going to twin headlights on my little chopper thing, one as high beam one as low beam.
    Do I ... run the ground to both, the hi beam filament wire to the ‘high’ light and low beam to the ‘main’ light?
    Or do I just have no idea?
    The lights I have are old beetle reverse lights and appear to have a single wire coming out. (In which case.. what do I do with the ground?)
  • brucefxdl
    brucefxdl
    7 years ago
    should be straight forward.common earth to both,providing it is not a negative switched circuit,earthing somewhere on the main frame [or existing head light earth ] and high beam wire to the light you choose for high,usually the top one and low beam will be the other.if these lights are the same and the low beam goes out when high beam is switched then you probably wont see any difference unless you use a higher wattage globe, as the lense's will be the same.but if low beam remains on at the same time you will get a little more light  but of the same pattern.cheers.
  • Mr.Mow
    Mr.Mow
    7 years ago
    Thanks guys, these are the lights, as for the bike and wiring it’s a late 70s XL, headlight is a basic H4 based thing.. pretty standard.
    I think Bruce is probably right. As for output, the current light is crap anyway, no long rides on this bike.
  • Mr.Mow
    Mr.Mow
    7 years ago
    Thanks guys! Was hoping it would be that easy!
  • Benno
    Benno
    7 years ago
    Mr Mow, I am far from knowledgeable when it come to auto-electrics, but to to make things simple I would wire them as one light on at low beam and both lights on at high beam. Maybe adjust the the direction down and possibly the bulb output on the low, that might just be my lack of knowledge ?.
    Benno
  • Benno
    Benno
    7 years ago
    Quoting Benno on 23 Jul 2018 06:52 AM
    Benno
    Sorry, should have read the entire thread first, as per what Bruce said.
  • Mr.Mow
    Mr.Mow
    7 years ago
    All worked as advertised! Thanks guys!
    But.. how would I go about getting both to come on for hibeam when all I have is a ‘lo’ wire and a ‘hi’ wire, both are grounding through the metal shells to their bases.
    Is it even possible? Keep in mind this bike was rewired for the bare minimum.
  • brucefxdl
    brucefxdl
    7 years ago
    Quoting Mr.Mow on 31 Jul 2018 01:59 AM
    you could fit a blocking diode to the low wire,current only passes on way,this will allow low beam to switch on but no current in the opposite direction,then connect a wire from hi to low with another diode to allow current from hi to connect at the light side of the low diode but blocking low current to the hi light....not simple but should work....if you have room for a lot of wire and bits,well seems easy to me.cheers
