Softail Dash Lamp Assembley Cost
  • AaBorokokok
    AaBorokokok
    7 years ago
    Hey all, new to the forum. My left turn indicator and high beams are not working anymore and after having a look around it seems that i have to replace the whole assembly. Does anyone know how much a dealer will charge for the part? Cheers
  • steelo
    steelo
    7 years ago
    Give us a bit more info AB about the issue and what happened leading up to the failure. Some of the fellas may have had similar issues. Welcome to the forum.
  • LOFTYBOB
    LOFTYBOB
    7 years ago
    Quoting AaBorokokok on 22 Jul 2018 10:40 AM
    It is a know problem with them, my Delux has had 2 of them replaced under warranty. How old is your bike?
  • AaBorokokok
    AaBorokokok
    7 years ago
    My bikes a 2013 Softail Deluxe. After giving my bike a wash the left turn indicator and the high beam indicator aren't turning on. Left indicators and high beams work just doesnt light up on the instrument panel. Any ideas on how much a dealer will charge for the part?
  • steelo
    steelo
    7 years ago
    Get onto the dash and bike wiring / plugs with a blower vac. Leave parked in the sun to really dry out.
  • AaBorokokok
    AaBorokokok
    7 years ago
    Thanks for the help guys... ill give it a shot. I only realised that the lights went out today when I went to go out for a ride. I washed the bike last week though so if drying doesn't work i might have to replace the assembly.
  • STEAMER
    STEAMER
    7 years ago
    The LED dash cluster is a sealed unit, Take the dome nut off  to take the Dash and speedo completely off, ( turn it over) then unplug the wires to the cluster, undo and replace with whole New cluster, My 2011 fxst cost just under $60. about 3 years ago. My left indicator tell tale went out. Then with in a few months same again, but second time was warranty. Takes about 15min to change
