Online:
beaglebasher, HD17
Siktail fender eliminator Breakout
spides666
7 years ago
Has anyone fitted one? I did LED lights quite a while ago on my number plate but I want to get rid of the indicators now. Harley shop have said it's $899 for one. Thinking I may fit it myself as even they've said labour will be a lot as they need to remove the rear fender (five minute job!) etc
The internet has barely anything on these siktails!!!
stevo fxsb
7 years ago
Not sure of the brand of Eliminator you describe???
I did the Bikecraft mod, was about 1/2 the price of the ChopZ Eliminator of the two available last year!
Removes the standard rear indicators [blank plates supplied] and tucks everything under the guard!
a) Yes, rear guard removed....first beer can!
b) Mine wasn't plug and play wiring, so cut and splice took place.....third beer!
c) Tested the wiring before I soldered...another can!
d) Soldered all fittings...can again!
e) Re-assembled...two cans!
So Five-minutes...No!
6pack...sounds about right!
Dealer quoted me 3 hours labor??
If your splicing wires and drinking (dont mix them up..lol), bout and hour and a half's work in real time [cans included]!!
Cheers and Beers
S
7 years ago
Thats nice looking, cleans up the tail section very well indeed!
Adrian1200CA
7 years ago
I just did the Bikecraft one this weekend. $685 and everything you need comes in the box. Instructions are shit but easy enough to do. Took me about 2 hours tops and that's with spending 15 mins trying to find the soldering iron (only needed for the number plate light the rest is plug and play.
