Online:
Hilly
Removing lens tint
Removing lens tint
GTEEZ
7 years ago
I would like to remove some VHT lens tint (with clear) from my indicators (too dark for my liking). I have Googled/YouTube'd and tried all the easy removal options like brake cleaner, petrol, paint thinners, brake fluid, turps, metho. Most are leaving the cover hazy if they work at all. I am experimenting with the front changeable ones but the rear are sealed so I want to get the process right before I attack them.
Any ideas out there??
Jayman6
7 years ago
Quoting GTEEZ on 04 Jul 2018 10:01 AM
Rubbing alcohol.
STEAMER
7 years ago
Prob find that the tint is all the way through the lense, so a lost cause
skirtster
7 years ago
cutting compound
GTEEZ
7 years ago
Quoting Jayman6 on 04 Jul 2018 10:36 AM
Rubbing alcohol.
Tried that too.
