Online:
beaglebasher, Merv
Auto Compression Release 103
panz
7 years ago
When installing a map using the screaming eagle pro super tuner at what stage and how do you enable the ACR theirs nothing on the help menu just says to make sure you enable it also can't find any thing on the web as well, I've loaded a map up several times and tried to find it but with no luck all I did was just about killed my lap top.
panz
7 years ago
Hilly thanks for that I would never have worked that out, Does your SEPST have to be hooked up to the laptop and bike while you going through all this I'm new to SEPST and still trying to get my head around everything,
