Online: beaglebasher
2015 Softail Standard cam upgrade
  • Wombat71
    Wombat71
    7 years ago
    Any information would be appreciated on those who have had experience with Andrews 54 & 57 cams, i currently have heavy breather, SEPST and Bassani Sweeper pipes, was wanting more mid range grunt as do alot of 2 up riding with missus. Was told to go the Andrews 54 but after searching this forum and others alot of people say 57 if you are not doing head work. Any information and guidance would be appreciated
  • Wombat71
    Wombat71
    7 years ago
    Thanks Hillyi for the feedback i will check them out
    7 years ago
    I agree with Hilly on all counts. The cr570 or 575 would be first pick. Andrews 57h is good. Their 54 not so good for your purposes. Their 48 is a very good low-mid cam.
  • Wombat71
    Wombat71
    7 years ago
    Thanks Fatbat & Hilly I have looked up the 570-2 and i think you have swayed me, will post a video in a few weeks when she is done, thanks again
  • Wombat71
    Wombat71
    7 years ago
    That is huge difference, i am keen as to get those cams, thanks heaps Hilly will be doing it within the next month so will post video of how she sounds before and after, really appreciate your input
  • Wombat71
    Wombat71
    7 years ago
    Got cams, lifters, adjustable pushrods, bearings,timing chains now off to get installed  next week.
    7 years ago
    Good stuff. What cams did you end up with?
    What pipe are you gonna run?
    Bet you’re excited. Agree tune is very important. Some skimp on this cost which doesn’t make sense to me at all
  • Wombat71
    Wombat71
    7 years ago
    Ye wxcited as cant wait thanks both for advise, still got my Bassani Radial Sweepers as cant afford new pipes at this stage. Went with Cyclerama 570-11 cams S&S adjustable pushrods, S&S bearings, FE4000 lifters
    7 years ago
    Quoting Wombat71 on 05 Oct 2018 08:07 AM
    Good luck with it Wombat!
    as been mentioned, pipes can kill the tune, if tight budget pick up Aussie made Sonic slip on's put stock headers.
  • Wombat71
    Wombat71
    7 years ago
    Cheers Krash ill check em out
