Online: beaglebasher, Merv
Is a re-tune needed?
  • matho1961
    matho1961
    7 years ago
    I have a 2017 Street Glide. I originally had the bike tuned with the Screamin eagle street canons (yuk) and an Arlen ness heavy breather. I since put the neighbour haters on (without a re-tune) and I'm considering removing the baffles. I still have stock headers and only the slip ons were changed. Just wanting to know if I would need a retune at all?
  • matho1961
    matho1961
    7 years ago
    Yes it is
  • DocGreen
    DocGreen
    7 years ago
    Quoting matho1961 on 18 Jun 2018 02:42 AMedited: 18 Jun 2018 07:27 AM
    Yep, pretty sure it's required to keep your warranty anyway but the bike will run better as a bonus.
    I bought a Super Tuner Pro (orange box), have heard the Street Tuner (black box) is only good for stage 1 which is what you have, but not recommended for further upgrades as limited in it's adjustability.
    DocGreen (also have a 2017 SGS with the HD hi flow round style filter, stage 1 cal and with a few smart tunes and runs very nice, standard muffs still)
  • matho1961
    matho1961
    7 years ago
    Quoting DocGreen on 18 Jun 2018 09:00 AM
    Appreciate your reply. Wont do anything until the tune then
  • Jayman6
    Jayman6
    7 years ago
    What exactly are the “neighbour haters”?
  • matho1961
    matho1961
    7 years ago
    Quoting Jayman6 on 18 Jun 2018 09:44 AM
    Slip on mufflers, I got thru J&P cycles in the US. I think I just bought them for the name. Lol.
  • DocGreen
    DocGreen
    7 years ago
    Quoting matho1961 on 18 Jun 2018 09:13 AM
    matho1961, apologies mate I just re read your post - really shouldn't try and multitask (missus was right again). If you've already had it tuned with the stage 1 cal it wouldn't hurt to do a few smart tunes after removing the baffles from the new muffs, may pick up a little extra and may not depending on tune before. From reading the US forums, these engines are very sensitive to back pressure, so you may lose low end torque.
    What tuner are you running btw? if its the HD tuner (either one) download the software if you haven't already and have a play - gets easier the more you use it. You will need the cables though if you don't already have them.
    Theres a few posts on here with links to software and tutorials to help.
    DocGreen
  • matho1961
    matho1961
    7 years ago
    Quoting DocGreen on 18 Jun 2018 10:56 AM
    DocGreen
    I have the SE super tuner pro (orange box). I truly wouldn't know where to begin with doing it myself but Id be happy to try. Without looking on youtube I guess Id have to download the software on my Mac then transfer it to the box and then somehow to the bike. Currently ive had 4 large JDs so Ill wait till tomorrow to try
  • DocGreen
    DocGreen
    7 years ago
    DocGreen
    Quoting matho1961 on 18 Jun 2018 11:25 AMedited: 18 Jun 2018 11:28 AM
    Hey mate, try this link for the software and tutorial to get started.  prosupertuner.harley-davidson.com/SuperTuner.aspx
    It does get easier the more you use it, especially if only doing small mods/changes - just take your time. I find it handy to have the laptop plugged in to power and the battery charger connected to the bike while playing around just so neither go flat in the middle of doing something.
    I entered all 1's for the VCI number to download the software - give your VCI number a go 1st.
    DocGreen
  • matho1961
    matho1961
    7 years ago
    DocGreen
    Quoting DocGreen on 19 Jun 2018 04:11 AM
    DocGreen
    Appreciate your help, I will give it a go. Thank you
  • matho1961
    matho1961
    7 years ago
    Ok thanks, ill keep that in mind
