Online: beaglebasher, Merv
primary overfilled??
  • cdvreede
    cdvreede
    7 years ago
    had my 2011 FXDC serviced by the stealer - just standard stuff, oils, filer, grease and the likes. Using SYN3 in engine and primary - standard for the tranny. All OK except for the gear shift - massive clunk when engaging and shifting and at times neutral hard to find. I know, most likely the primary overfilled...
    Now in the olden days (2003 Ultra, '96 FXD) it was easy to check the levels - just pop the inspection cover and check level. Now of course there is no more inspection cover so no idea how to check the level... Any ideas?? use the Clutch cover to check level?? Or should I just drop 100ml out of the primary and see if that improves things??
    thnx
  • Fat Tom
    Fat Tom
    7 years ago
    mate , take the derby cover off and see if the fluid is level with the bottom edge. Simple
  • gidgi
    gidgi
    7 years ago
    Quoting Fat Tom on 16 Jun 2018 03:35 PM
    bottom edge  of the clutch plates I`m sure he meant to write
  • Baloffski
    Baloffski
    7 years ago
    Quoting gidgi on 16 Jun 2018 10:12 PM
    Hey Gidg, you on the ball for sunday morn.
  • cdvreede
    cdvreede
    7 years ago
    measured on side stand or upright??
  • KiwiRob
    KiwiRob
    7 years ago
    Quoting cdvreede on 16 Jun 2018 11:39 PM
    Upright. - Rob
  • FONTANA302
    FONTANA302
    7 years ago
    7 years ago
    Pays to check your clutch push rod adjustment too if you have your derby cover off! just saying.
