Bloody Harley won't start
  • dnkhughes@bigpond.com
    7 years ago
    Hi there guys n girls
    I have a 2013 CVO road king i went to start it today the thing miss fired on start and now when i go to start it doesn't turn over and something clicks the dash lights go out and the bloody alarm keeps going off. I put a new battery in the fob and the bike also has a new battery. PLEASE HELP. cheers
  • leachy
    leachy
    7 years ago
    Loose battery or poor grounded battery. the alarm system is thinking that the battery is being disconnected. Check all the battery terminals are tight. Is it really cold where you are?
    Regards
    Leachy
  • Baloffski
    Baloffski
    7 years ago
    Earth -Man..for starters, always look at easy shit when pissed off, then look at harder shit when on the ball.
    My philosophy anyway.
    7 years ago
    Clicks once or clicks a lot?
    7 years ago
    Thanks for the response fellas Leachy nailed it loose battery connections thanks for that
