For Sale - Dyna Low Rider Rear Wheel/160 Tire - Fit Dyna/Softail/Sportster
mitch199
7 years ago
For sale is the stock rear wheel off my 09 Low Rider.
Has a Harley Davidson Dunlop 160 tire in great nick, many kms left on this one.
Rim is the upgraded chrome 'profile' rim, a smooth finish that looks awesome, like a big chrome disc. Much nicer than a shouldered rim.
Comes with HD Sunstar Disc, and has standard 25mm bearings for HD's 09 and up.
This will fit a huge selection of bikes if you organise the right spacers, or even pop out the bearings and fit your own ones in.
Will roll directly underneath Dyna with Standard spacers from 06-17 (the death of the Dyna).
Would fit basically any Harley (standard 6.5" Hub Width) if you want to upgrade to a 160 rear tire and chrome spoked wheel.
Pickup Available Eastern Suburbs Sydney or can post Aus Wide for around $45.
$250 firm. Only selling as I've bought a 200 rear Fatboy wheel that I am slowly massaging under the Low Rider.
Contact me through messages if you are interested.
mitch199
7 years ago
Thanks Hilly,
The wheel is a 17"x 4.5" wheel so will need an appropriate 17" tyre. Cheers.
mitch199
7 years ago
I just checked the tire size you quote Hilly.
That tire is meant for a 16 x 3" rim. Cheers.
mitch199
7 years ago
Still for sale guys if anyone is looking. Will do $200 for the rim, tyre, disc combo. Cheaper than a tyre.
