Online:
beaglebasher
My 2000 Harley Davidson fatboy's rear tyre scrubbing out
SLIDA74
7 years ago
Hey peeps...got an issue with my rear tyre scrubbing out on the fender both sides fairly bad...I haven't changed anything it's just started doing it..any help would be appreciated..tia
7 years ago
Where is it rubbing? Top of fender, back etc? Same spot on both sides? Everything done up tight - fender and tyre? Has your arse gotten fatter? No new tyre recently?
If you lift the bike off the ground what can you move side to side back there?
SLIDA74
7 years ago
Quoting Bonkerz on 08 Jun 2018 06:52 AM
It's rubbing along both edges of tyre..quite bad..My camera on the blink so can't take any pics grr.. everything seems tight..Ive lost weight not gained lol..ill see if I can get some pics up shortly...bloody frustrating
robnicko
7 years ago
check your tyre for bulging. could be the steel belting compromised internally. how old is the tyre?
also check that the inner plastic guard has not dislodged?
