Online:
Stuart
Oil changes - easy as....
Muzza Wa
7 years ago
Check this out, I just stumbled across it on the web, probably 100 years old, but I thought it was interesting enough to share!
http://ezoildrainvalve.com/index.html
The also fit HD’s
Harley-Davidson
Some Engines -
1/2"-20 -
EZ-101
Some Engines -
5/8"-18 -
EZ-102
Video
https://youtu.be/6MBJTdsiSuQ
robnicko
7 years ago
first thing that comes to mind is someone turning the lever and letting the oil out........and then there's vibration slowly loosening the mechanism....
Muzza Wa
7 years ago
It’s supposed to not vibrate open because of the method used to open it, press up and rotate? Anyhow I just thought it was interesting enough to share.
Baloffski
7 years ago
Muzz is really interesting.
If had a large vehicle ie: Kenworth or similar, would not use, as a spanner is chaeper than a new engine.
But, in saying that I reackon the concept is great.
7 years ago
We have these on some of the machines at work. Do make life a lot easier and never had a broken or leaking one. Vibration doesn't bother them at all.
