Online:
beaglebasher
V&H Throttlepak - newer version or similar product?
Bandit2011
7 years ago
Hi guys,
Anyone know if the V&H throttlepak for 08-13 tourers will work on 2016 RoadKing? Or is there another product out there that does the same thing? Gotta lose the lag....! TIA
Big Steve
7 years ago
Do you mean the Fuelpak?
It is married to the ECU, so you cannot interchange between bikes. (Well you can plug it into anotehr bike to read fault codes but not load a tune)
Powervision can interchange between bikes.
Bandit2011
7 years ago
Thanks Steve, I emailed V&H and they confirmed there is a feature on the FP to adjust throttle response. Cheers
