Online: beaglebasher
Turn signal light bar
  • binnsy
    binnsy
    7 years ago
    Thinking about some saddle bags for the fatboy but need to relocate the indicators.  The rear turn signal light bars dont look too bad.  Not sure how they attach though, seems to be a couple of small bolts, maybe drill holes in the guard?  Not mad keen on doing that, has anyone fitted these to a fatboy.  Mine is an 07.
    Anyone got any for sale as well ?
  • Evo
    Evo
    7 years ago
    There is a set on ebay for $100.00.  New, cost is around $180.00.
  • STEAMER
    STEAMER
    7 years ago
    Binnsy,  i bought a set of fender bracket extenders, the move indicators back about 50mm. They are chrome and reasonably hard to tell they are there. As they look same as last
    50 mm of the fender brackets,
  • binnsy
    binnsy
    7 years ago
    Quoting STEAMER on 29 May 2018 10:47 PM
    Where from Steamer?  Had a quick gooogle couldnt find any
  • Muzza Wa
    Muzza Wa
    7 years ago
    Quoting binnsy on 30 May 2018 12:51 AM
  • binnsy
    binnsy
    7 years ago
    Thanks MuzzA. I must've had a boy look !!
  • STEAMER
    STEAMER
    7 years ago
    Off ebay, was back in 2012, only about $59. by memory, They look neat. as per the pic Muzza  posted.  I am sure it was Harley Heaven , A-Beckit st Melbourne
  • binnsy
    binnsy
    7 years ago
    Thanks STEAMER think they're like  $150 these days
  • STEAMER
    STEAMER
    7 years ago
    Try Gum tree or Ebay. Someone might have a set
