Online: beaglebasher, ryno_0000
horn wiring
  • Lozz
    Lozz
    7 years ago
    Does fxdb already have a horn relay or do I have to fit one for air horns
  • 98fxstc
    98fxstc
    7 years ago
    no relay in my Fatbob, doubt you have one for the horn in the Streetbob
    most air horn kits come with the relay to drive the compressor
    I just fitted a Denali SoundBomb to mine and hooked the in-line fuse up to the positive on the starter motor because it was getting a bit crowded in the battery carrier
  • Lozz
    Lozz
    7 years ago
    Quoting 98fxstc on 28 May 2018 11:15 AMedited: 28 May 2018 11:16 AM
    Strange for Harley, I made bracket for horns with compressor hidden in cowbell & tested using original  plugs for horn & they worked great.
    Didn't stuff around fitting the relay as they. work so good even with engine running they are so loud.
    Tilted them downwards a bit to try & prevent them filling up when raining.
    All up cost was about $30, the horns & compressor were $24 from ebay, a few nylock nuts & a thick piece of aluminium plate.
    Wasn't prepared to pay the big dollars that a lot of "Harley" accessory ones cost.
    If they corrode or pack up, will just get another set, but the chrome looks ok & I will polish them to preserve finish
