rinehart kickbacks
rinehart kickbacks
marce
7 years ago
Hello Guys,
I have been wanting pipes for ages but the cost really was the factor that stopped me.
It was around xmas that easyr had these rinehart kickbacks for close to $500, so i went for it.
Installation was easy, brackets, bolts and screws all supplied, the dude i spoke to suggested i get some gaskets, but rinehart had already had a couple in the box. The quality of the rinehart products are good(but i havn't bought pipes from anyone else) with no complaints.
I have tuned it all up with the tts and is running sweet(thanks for the help hilly), has a great sound and not as loud as i had thought.
The only issue i have is that the front pipe is lower and has reduced the lean angle, my thinking is that they have not tested it on a fat bob prior to release, as you can see from the photo there is plenty of room to have them a bit higher, on the other hand changing the angles of the pipes may have cause decreased performance, i don't know enough about this so it's just a guess.
Would i buy them again......for the price, i think they are good value for money, so yes.
marce
Baloffski
7 years ago
marce, they do look good. But, might be the angle or my perception that front and rear outlets do not seem to be parallel?
marce
7 years ago
here is another photo angle..... tried to raise that front pipe has much a possible, but could only manage 1 cm or so.
dyna13
7 years ago
Hard to tell in pics if done or not but could drop the forks a little, flush with top triple tree made a difference on my old Wideglide for clearance. Taller front Tyre next time due?
