rear guard tyre clearance discrepancy
snoozy
7 years ago
My 2010 St bob has a 180 rear so the clearances are reduced anyway...but I've noticed the left side clearance from the tyre is around 7-8 mm and the right side is more than double that. Q: is it normal for them to be asymmetrical even with stock tyres on? Or is something amiss?
7 years ago
Most harley wheels are offset std from factory
