Online: speedzter
front tyre wear
  • Fat Tom
    Fat Tom
    7 years ago
    hey, guys here's a pic of my front wheel on my fatty. It has noticeable extra wear on the RH side to the extent where it is almost like a plane has been taken to it. The previous tyre was the same and this one is now 8000km old, Ive been told this is normal because of the camber on the road but I'm wondering if there could be a mechanical side to this as well such as front suspension. Would love to hear your thoughts and experiences as the way it's going I'll only get another 1 or 2 thousand km before having to change out. I rode a lot of smaller Jap bikes when I was younger and never had this issue
  • keith
    keith
    7 years ago
    Have you ever changed [new] the wheel bearing Tom ?
  • Fat Tom
    Fat Tom
    7 years ago
    No bike is coming up to 40k maybe when the tyre is off next Ill change it. Last time I checked bearing was fine and I'm not hearing any noises etc.
  • keith
    keith
    7 years ago
    When you start hearing noises is a bit late, process of elimination, preventive maintained always is the cheap option. IMO.
    Good luck with your trouble shooting.
    7 years ago
    Didn't Mickles tyre just do this same thing?
    7 years ago
    Not sure but read somewhere about the offset on some models and a fatboy was one of them.
  • ryno_0000
    ryno_0000
    7 years ago
    Ive had the same wear on all my tyres. The camber coupled with right turns being a longer distance than left leads to this happening.
  • steelo
    steelo
    7 years ago
    Left hand turns around a city block is shorter.
  • robnicko
    robnicko
    7 years ago
    the offset Pauly mentioned, you should know easily if your bike has it by looking at the gap between the forks and guard from the front. It has something to do with when the 200mm rear was introduced I think
    It was corrected in 08 I believe.  Not sure if that is the main cause though
  • mickle
    mickle
    7 years ago
    Don't listen to the Camber bullshit, we all rode side by side and only the Fatboys tyre wore on the right side, when I
    had the new tyre fitted at Hidden Valley Harley it felt like a truck not sure what they did, was guessing it was just the feel
    of the new Commander 2, it wasn't, I fitted a new Commander 2 and wheel bearings, adjusted headstem bearings at Great Southern Albany
    and now 3,oookms latter it still looks brand new. I am guessing the fucked up the install and bearing adjustment in Darwin.
  • Fat Tom
    Fat Tom
    7 years ago
    thanks guys I think Ill do the steering head and wheel bearings next tyre change and see if it makes a difference.
  • chriso
    chriso
    7 years ago
    It’s the taper of  the rd, most taper from the centre out. If we rode on the right hand side of the road over here the wear would be on the left side of tyre.
    Is nothing whatsoever to do with the bike.
    If you don’t believe, have you ever seen this wear happen on the left side of a tyre... anyone? didn’t think so
    I’m guessing it don’t always happen because of softer and harder compound tyres, maybe as in Mick’s case once he changed brands.
  • steelo
    steelo
    7 years ago
    I tell ya what I did find out. (while I was sipping my latte, snorting coke and using other drugs)
    That going anticlockwise V clockwise around Australia is only
    wait for it...
    about 19kms
    Not really enough to make a discernible difference in the wear of a tyre.
