Online: B0nes
Chop Windshield
  • Muzza Wa
    Muzza Wa
    7 years ago
    I just cut mine using a Dremel with the Perspex cutting disc. Had to cut it to suit fright train nacelle. I went to Clark rubber and bought a meter of slotted rubber gasket to cover the imperfections of the cut.  Looks fine now.
  • STEAMER
    STEAMER
    7 years ago
    Cut myself. Bought perspex blade for jigsaw. Put tape either side marked line to be cut sa not to scratch screen. Took about 5 min to cut. Then light gauge sand paper to sand edges
  • imoo6170
    imoo6170
    7 years ago
    I regularly use these guys new screens, cuts etc  http://www.handcraftfibreglass.com.au/
    Open on Sat mornings and normally take a week to get it done.
