Online: flstc08
Easy clutch pull kit Breakout
  • Skbreakout
    Skbreakout
    7 years ago
    Hi does anyone using easy clutch pull kit on there breakout 2016 or similar. How hard is to install? Looking to get for my breakout. Any suggestions please. Cheers Sk
  • DarkHorse58
    DarkHorse58
    7 years ago
    Just installed Roland Sands adjustable levers on my 2017 Dyna.
    Not a clutch kit as such of course, but makes an appreciable difference to ergonomics. Just easier to engage the clutch.
  • Skbreakout
    Skbreakout
    7 years ago
    Today install the easy pull clutch kit and it made a big difference in pulling clutch. Way to easy cheers
  • binnsy
    binnsy
    7 years ago
    Quoting Skbreakout on 25 Jun 2018 05:13 AM
    Where did you get it from ?
  • Skbreakout
    Skbreakout
    7 years ago
    Quoting binnsy on 25 Jun 2018 10:42 PM
    From USA. Easyboy Clutch Kit 07-0670 1130-0183. Cost me Aus $47.23 with delivery. It is more than worth for this price. Cheers
  • Kato
    Kato
    7 years ago
    Quoting Skbreakout on 26 Jun 2018 01:48 PMedited: 26 Jun 2018 03:52 PM
    i could understand an "easy pull" clutch on a pre 06 HD ( as they require a LOT of effort) .......you could purchase a kit from HD to make it easy to pull in the lever
    Post 07 the clutches were upgraded by the kit mentioned above (in pre 06 models) being installed in all models post 07 .
    so.............the Breakout should be quite easy to pull in ( given the upgrade since 07) .............plus isn't the clutch hydraulically actuated now ???
  • Skbreakout
    Skbreakout
    7 years ago
    Quoting Kato on 26 Jun 2018 10:02 PM
    Yes it is Hydraulically clutch. But still for me after riding in mountain road for 2 hours my fingers dont want to press the clutch n have to use my hand to press it. This kit is easy to fit n now i can press the clutch with very less effort. I am happy with it n for $50 its a another comfort for me. I am sharing my experience here. Cheers
