Online:
John.R
Decent Independant Mechanic
7 years ago
There used to be three options but now only two. One is the dealer and the only dyno operator for Harleys in town. The other is an Indy I use. Bestway choppers and customs in conder. He's online and on Facebook I think. Runs out of a workshop at his house. Name is Jason (Bear). I dunno if either of the two options will do any crank work. I think they'd send it off somewhere else.
Good luck I think you've got the heads I wanted to buy haha
7 years ago
Haha I might take you up on that one day.
Jason's very meticulous and I'm sure you'd be happy if you used him. He's also an s&s dealer re the crank. I think you're doing the right thing getting the upgraded crank after getting those heads onto the 117 which is probably pushing the limits of the oem bottom end. I wouldnt be surprised if the dealer tried to talk you out of it or didn't want the job.
chriso
7 years ago
Better elaborate on that.
Harley shop can build you a reliable engine, but not really open to anything but SE gear and will hit you hard. They also put a tune in to get you running but if you are fussy and want
a good custom dynotune you will have to branch out of Canberra.
chriso
7 years ago
Sent a PM bud
