Online: John.R
Which Loctite - Sporty top front engine mount?
  • Amberwhiskey
    Amberwhiskey
    7 years ago
    I've made up a mounting bar to fit driving lights to my Sporty which will bolt up to the top, front engine mount bolts on the downtubes.
    After I remove them to fit the bar what breed of Loctite (if any) should I use when I refit the bolts?
    Thanks in advance!
    7 years ago
    Blue would be fine for your application  not sure what virtual t is on about but the factory use red and
    Blue with alloy  prime example is disc rotors / drive belt pulley  . Red can be a pain in certain applications
    Check out the other posts on the different types of loctite
  • Amberwhiskey
    Amberwhiskey
    7 years ago
    Thanks for the advice gents, will grab some.
    I have to buy a workshop manual too, preferred manual (aftermarket?)
    Bike is a 2016 1200 Custom.
  • Hound_Dog
    Hound_Dog
    7 years ago
    For my bikes, if it comes off it goes back on with Loctite. Its that simple.
