Online: John.R, speedzter
CHANGING ODOMETER FROM MILES TO KLMS
  • creaking bones
    creaking bones
    7 years ago
    I've just taken my 2018 Harley Deluxe for it's first ride. Speedo needle registers klmsper hour but the odometer records in miles. I can't find a reference ion the handbook on how to change it. There must be a simple solution. It's over 200 kls to the nearest dealer and I'd like to do it myself. Any ideas out there?
  • Kingchops
    Kingchops
    7 years ago
    With my bike you can change between km and miles by holding down the trip button for two seconds when viewing the odometer.  I'd imagine most newer bikes would have that feature.
  • creaking bones
    creaking bones
    7 years ago
    Thanks KC, I'll give it a try. Makes sense to me.
  • creaking bones
    creaking bones
    7 years ago
    Thanks again KC, you are spot on with your info.Problem corrected in two seconds flat.
