Online: John.R
Bobber fender progress..
  • mrjessehlee
    mrjessehlee
    7 years ago
    Hey all! Just thought I'd share what I've been up to with my build.
    I'm now in the process of building the rear fender.. trying my best not to steer too much away from ADR and ended up with this!
    Its just a mock up in this moment in time but gosh I hate the looks.. hahahah
    The rear signals stick out like a sore thumb :(
    If it wasn't for the ADR I'd have the side mount plates and be done with it too.
    Any suggestions would be much appreciated!
  • mrjessehlee
    mrjessehlee
    7 years ago
    Looks 100 times better without the number plate.. argh..
  • bungle
    bungle
    7 years ago
    Nice lines, with the support strut are you going to angle the top towards the fender (like in the pic) or put a pin in the fender and have it  run straight up n down?
  • mrjessehlee
    mrjessehlee
    7 years ago
    Spend an afternoon welding the tabs in place before spray paint and this is what I ended up with.
  • limpn
    limpn
    7 years ago
    looks unreal.. love the bobber style
  • Omzz48
    Omzz48
    7 years ago
    The progress is looking Mickey Mouse !
    What size rear tyre is that?
  • Arron
    Arron
    7 years ago
    Looks good.
  • mrjessehlee
    mrjessehlee
    7 years ago
    Thanks all,
    After contemplating, I've decided to return the lights and go with custom dynamics all in one frame.
    Has anyone installed it successfully on 2018 softail model? With no wiring from the front lights and no dash codes?
  • mrjessehlee
    mrjessehlee
    7 years ago
    progress..
