Online: Stuart
Floorboards on SB
  • Bob13
    Bob13
    7 years ago
    Howdy
    Just did a 620kms trip this weekend and was feeling it a bit by the time I got home.Im 6,3 and I have forward controls on the bike.
    By then end of the trip I was really starting to feel pain in my inner thighs and hips.
    So I was wondering if I could put boards on it in the forward position and if it looks half descent.
    Also do they affect the lean angle much more than pegs.
  • Paz141
    Paz141
    7 years ago
    You could look at pushing ur controls futher forward or adding  some crash bars with foot rests, it will allow you to stretch your legs out.  Floor boards do reduce your lean angle a bit, my fatboy improved alot when i got rid of the boards and put forwards on.
  • JFE
    JFE
    7 years ago
    HD used to make a mini-fb that may solve your problem. There is also the other option of a foot peg that has a heel resting place ‘built in’ that can be flipped out on the move. Kuyrarkyn I think makes it?
  • butch
    butch
    7 years ago
    I put switchback boards on the misseses 17 low rider had to go for side shots as big radius didnt fit i am six foot and i think it is just as comfortable as my road king nearly cheers
  • Ferrett62
    Ferrett62
    7 years ago
    Mini footboards, got them for the wife as pillions but she hasn't been on for a while so decided to try them on the front. Can be adjusted to any angle and give a good feel under foot.
  • Bob13
    Bob13
    7 years ago
    Thanks all for the replies,Im also looking at mx style pegs.Has anyone tried the SGS Bear Traps?
  • Bob13
    Bob13
    7 years ago
    You guys are so helpful.As for the items you guys asked about  I couldnt see anything on the website.
    Maybe try Oxford St in Sydney they would definately have something you all could adapt on to your bikes.
  • Ranga
    Ranga
    7 years ago
    I know, i'm a bit late here but I fitted full Floorboards and levers etc off a 2015? Switchblade onto an 07 Superglide. They bolted straight up and work like a charm.
  • STEAMER
    STEAMER
    7 years ago
    Quoting Bob13 on 15 Apr 2018 08:59 AM
    Howdy
    I have a 2011 fxst, when i  injured my back at work, i changed my forwards to floorboards, so as i can move my feet around all the time to give my back and left leg sciatica a bit of less pain, lets me ride longer
  • STEAMER
    STEAMER
    7 years ago
    Look good, they suit the bike
  • STEAMER
    STEAMER
    7 years ago
    Same here, Kuryakyn. Iso  I have for front and rear boards & gear selector / brake pedal & grips.
