Online: speedzter
What are dealers charging to fit new tyres
  • Ozbernie
    Ozbernie
    7 years ago
    Ive just priced new tyres for my 2014 SG at the local dealership in Bendigo and they want to charge 2 hours labour to remove and refit.
    That seems excessive to me and makes a set of tyres fitted around $820
    What are others paying?
  • mickle
    mickle
    7 years ago
    Harley Heaven in Melb were fitting tyres with no fitment fee, might be worth a call.
  • Ferrett62
    Ferrett62
    7 years ago
    My local dealer does not charge fitting if you buy from them if you bring your own tyres will charge 80 I think they said.New pirelli night dragon front fitted 160 tyre 144.55 disposal of old 0.90 gst 14.55.
  • SRV72
    SRV72
    7 years ago
    I have ordered a set of Avons through my local dealer. They have offered competitive prices and said that they never charge for fitting. Its included in the cost of the tyres.
    7 years ago
    About $500- to $550- . Harley Dunlops .
    7 years ago
    I would have thought around 1 hour labour to remove and replace a set of wheels would be fair depending on model.
  • steelo
    steelo
    7 years ago
    Hi there. Just checked in with Adelaide Bike works 81771277
    For that bike, Harley tyres, $221 for front, $305 for the back. (he did say $575 total so there could be a little fitment fee, but not 2 hours!!)
    Why don't you make a trip to SA to get em fitted, let us know and catch up with some of the local forum members
  • Omzz48
    Omzz48
    7 years ago
    That’s a bit steep for sure, I’ve always bought tyres from America j&p cycles never had problems with them and just got them fitted at local work shop charges $100 to fit, just shop around, someone will beat that price easily
  • Harley Breakout Guy
    Harley Breakout Guy
    7 years ago
    stay away from dealers they will rip you off - local hd dealer wants $450 to $500 to install and supply rear tire for a breakout - i got it done at tire store for $330.00
