883 Wanted& OTD PRICE NEEDED!
  • jaselzs33
    jaselzs33
    7 years ago
    Hi guys,
    I'm looking for 883 as my first bike, what is your out the door price for 2018 iron 883 (new stock)
    BTW should I go for brand new or used? is there a big difference between 2015 and 2018 editions?
  • Kingchops
    Kingchops
    7 years ago
    Not sure why you're asking on a forum for OTD prices, this isn't a dealership.  Buying a new 883 is a bad idea, there's a new Iron 1200 for basically $500 more than the 883.  If you must buy an 883 definitely look for a second hand bike.  Also take into account the effect the new Iron 1200 will have on 883 used bikes.  They won't be worth what people paid for them, or are asking for them in many cases.
  • steelo
    steelo
    7 years ago
    Hi Jase. (KC, I hope its OK to mention the dealer?)
    Adelaide Bike works in Adelaide have new one's from $15,995.00. They have a few trick looking second hand ones at the moment.
    Allan, one of the salesmen says to give him a call on 0881771277
    or go to Web site and have a look.
    I like these guys
    Good luck
  • Ratbob
    Ratbob
    7 years ago
    Also when you are at the dealership they will make up a list of all the parts you want changed and a quote for fitting, that way you will have a total cost before you buy.
