Online:
beaglebasher
Replacement Battery Breakout
Breako
7 years ago
Hi - I need a replacement battery for Breakout
I only got 18 months out of Battery- bike is 18 months old - HD dealer says that is normal now ( 2 years max is all they last )
Battery has been on Trickle Charger since new
There has to be a better battery out there
Is anyone using a Lithium Battery ?
Cheers Bill
Far Canal
7 years ago
Normally the stock HD batteries are really good. I got over 9 years out of mine. Perhaps the warm climate in Townsville is not ideal for a long battery life?.
Arron
7 years ago
The original battery in my 2013 Street Bob lasted about 2 years , the second replacement HD battery is still going ok but i do keep it on a trickle/float charger most of the time.
I think i did kill the original battery when i left the aftermarket grip heaters on for 1/2 a day (wired them up correctly after that).
Chaser
7 years ago
Had EXACTLY the same happen to my Breakout after 14 months. Battery was absolute crap. Got another HD battery.....might regret it now!
Breako
7 years ago
Thanks everyone for your input - I ended up going with another Harley battery (Yuasa)
