Online:
Merv
Primary noise advice
Ferrett62
7 years ago
So I am new to harleys but I know the motors make noise but I was sure there was something making a noise that wasn't right, so I decided to pull the outer and have a look. I checked right through and there was nothing, no marks on compensator, clutch basket or chain till looked inside the outer cover.
This is the bolt hole at the front just below the compensator and the marks look very much like the chain.
I am thinking of grinding this down to give more clearance and it looks like there is plenty of meat to remove without weakening the mount, any ideas why it is doing this and is grinding a good idea.
7 years ago
The tensioner should prevent that. But grinding a bit away wont hurt.
Ferrett62
7 years ago
Thats what I thought and thats why I am asking, all looks normal inside but don't know what to look for.
markwoumla
7 years ago
What year and model bike ????
I can see the small indentations/scratches ,,, but I have not seen where the mold has been grinded away , (looks like purposely), where the scratches are ....
Below is pic of 2009 touring model ....
Ferrett62
7 years ago
Mine is a 2011 blackline and it would be the left hole but on the outer cover.
98fxstc
7 years ago
Doesn't make any sense
the chain feeding off the bottom of the compensator sprocket is not going to move that far sideways in that location now matter how loose the adjuster is
you say you are new to harleys and the bike is 2009 touring
my guess is a previous owner has had some problems with it
the compensator bolt may have come loose and allowed the compensator to move out
or something hanging off the side of the chain and flicking the cover as it goes past ?
Doubt it is a problem now since that chain looks ok
if you have a noise look elsewhere
most compensators/clutch/primary chain are a little noisy
check everything for slop (clutch basket too)
button it up and use a screw driver to check for noise at that location and elsewhere
keep an eye (or ear) on it but don't stress too much
could enquire with the previous owner or Dealer and may find an explanation for that
markwoumla
7 years ago
I thought we were looking at the
inner primary housing
area , not the
outer cover
,, my bad .....
What is strange is your outer cover mold has been grinded away purposely , (well it looks like it anyway).... See pic of outer cover I got from internet showing no grinding....
For whatever reason that grinding on your outer cover was done,, it was not done to clear the chain , as the chain could not possibly hit that area.. No doubt something happened in the bikes previous life,,,, (as 98fxstc mentioned)....
As your new to Harley's , I don't want to give advice on messing around in the primary... But you could re torque the compensator,,, clutch hub,,, and the primary tensioner assembly bolts .... if everything looks ok, and there is no foreign matter in there , button her back up ,, fill up with fluid ,,, and see if things change.....
On a side note,,, I had rotor cover crack once,, and strips of metal pieces were flung around the primary,, (has been know to happen on the older rotor covers).... I didn't hear any strange noises ,,, only found out when I replaced the compensator... I was lucky as the metal pieces got wedged up in tight places away from the chain etc, and primary operated as normal ....... Don't know if this helps ,, but check the rotor for cracks and/or missing pieces ,,, double check for foreign matter in the primary ......
7 years ago
It's pretty obvious it is the primary chain touching the outer.
Some models have the primary chain running partly outside the inner primary.
It is also obvious the outer has been milled for clearance from the factory.
A pic of the inner primary showing the chain will clear things up.
Ferrett62
7 years ago
As I said there was plenty of meat on the cover to grind some off so I took of the marks and a bit more and there was still of the cover left for strength. I don't know if this was the noise I heard but I feel better after looking, I have no idea how the chain could have contacted at this point and everything in the primary looked like new and a thing of engineering beauty. I did start the bike with the cover off for a short time and the chain ran perfectly with flex only along the top long run and none where the marks would have been but there was strain of changing up or down through gears, just have to listen for the odd noises and live with it.
