Online:
beaglebasher, John.R
Australian Blinker setup on an imported 2015 Ultra
Bonnie
7 years ago
HI
I,m trying to convert the blinkers of my 2015 Ultra limited to to Australian setup (I bought the bike in US)
The Harley dealer is telling me that I may need a new back mudguard as the current one does not allow the installation of the turn signal bar
I was thinking if there was a way to change the current blinkers that are in the topbox to yellow??
Any ideas
Ratbob
7 years ago
Changing to yellow or clear or smoked will do (use yellow globe)
I looked up an OEM parts finder and it looks like there’s an international replacement for the lens housing so a dealer should be able to look it up for you and tell you what’s available . Seems to be plenty of OEM indicator mount options too.
Could be expensive though.
Bonnie
7 years ago
Thanks what are OEM parts.
Very new to Harley. Bought the bike last may and toured for nearly 6 months (28 thousand miles) lots of fun
The US model has the blinkers in the top box and they are red.
There is a signal bar made but it apparently doesn't fit my fender
Ratbob
7 years ago
Hi Bonnie
Go to capital.hdspares.com.au
Top left side under the HD emblem you’ll see OEM lookup. Click that and then search for your bike etc, each subsection brings up a diagram of the parts available for both US and international bikes.
Entering 1 in the little box on the left and hitting enter takes you to a page showing the HD part no.
It’s a good ref tool. Cheers.
mickle
7 years ago
This is a couple of rear shots of the standard Oz guard that I have spare.
steelo
7 years ago
Gee. That bike was a delight Mickle.
