Online: WideglidingNZ
Ignition coil pack single or dual fire ??
  • Ben koolen
    Ben koolen
    7 years ago
    Hi I have recently bought a Daytona tec module and am wanting to use single fire mode. my bike came with an aftermarket crane cams coil but am not 100% sure that it is a single or dual fire ? Hoping to get some help here are some photos cheers
    7 years ago
    what year is your Sportster?
    I can only see two wires in the pic, they say single fire has three wires to the coil. I have had Harleys both, single and duel fire. was nothing in it power wise. I also had a dual plug set up on a Shovelhead that was single fire & no power gain over single plug dual fire. just ignition does not work as hard. some double coils single fire but the set up I had used two coils separate, most coils like you have fire together
    7 years ago
    two wires is single fire...+ve and a -ve feed only (oddly enough they normally open circuit the negative to fire the coil)
    three wires is single fire... 1 x common feed for front and back (in my case its the +ve) and then the separate feeds for front and back trigger.
    four wires is the same as three as you end up connecting two of the connectors together.
  • Ben koolen
    Ben koolen
    7 years ago
    Thanks guys I think I shall just leave it on dual fire mode anyway for now might try a single fire down the track cheers:)
  • Ben koolen
    Ben koolen
    7 years ago
    Interesting .I have a 1993 xlh1200 with 80 cube motor .I got the twin tec 1006:)
