Online: Merv
Oil pressure.
  • coyoty
    coyoty
    7 years ago
    As dont have gauge could someone who has please supply oil pressure  of  machine same or similar to 2000.    1450 cc.    At idle please !  Thanks folks.                                       And Tussuck, trying to make contact with you regarding turbo post.  Cheers.
    7 years ago
    I have a 2000 with a gauge, but don't have a stock oiling system.
    Hot idle, you could see as low as 5 psi, maybe lower.
    Mine will stay over 15psi hot idle, ~ 35psi at 3000 .
    Go to your local parts shop and buy a cheap ($40) mechanical car gauge and measure it.
    7 years ago
    Yep as speedzer said oil pressure drops of when hot at idle low I’ve seen my evos  drop down
    To  8 or so psi on a hot day in traffic but if you goggle e.r.t products in the states thay make a
    Relief spring upgrade kits for harleys to tailor your oil pressure .   depending on what climate
    Your in oil cooler helps too
  • Hound_Dog
    Hound_Dog
    7 years ago
    Volume is more important than pressure.
    7 years ago
    i use 25/70w
  • coyoty
    coyoty
    7 years ago
    Thanks for reply,  i think relief upgrade is the answer for my situation.    and buy a gauge.   cheers.
    7 years ago
    20/50 is like water in da summer esp in a Dyna with only 2.5 ltr oil tank thats under da motor & get's a lot of road heat
    7 years ago
    Ert products  mention  a test similar to what you have said on there web site by memory mr hood
  • coyoty
    coyoty
    7 years ago
    Thanks Perthhog and Hoodeng.    Reason i need oil pressure at idle is for Turbo as one i have is bush as opposed to bearing.   dont want to chance it running without enough fluid.
