Powder coater recommendation near western sydney.
mrjessehlee
7 years ago
Hi guys,
Does anyone know of a powder coater near Blacktown, Hills district or parramatta in NSW area?
I am looking into powdercoating a chrome parts.
and,, in general, is it possible to powder coat a chrom parts?
Thanks all!
John.R
7 years ago
Depends on the part but if it's fresh and new chrome chances are they won't do it or wont guarantee a good finish.
They can sand blast it to rough it up but ir may not stick.
They ll likely recommend u get the parts stripped properly then PC
imoo6170
7 years ago
I have used this mob. Did a good job for what I wanted but it wasn't a Chromed bit, give them a ring and see what they say:
https://www.precisioncoating.com.au/
7 years ago
Have had plenty of chrome shit powder coated no issues as long as the chrome is not lifting in any spots
If so it needs to be removed have had new and old chrome done been on the Bike a few years now
Only down fall is if you do knock it hard enough it can chip than you can see the chrome sometimes
Thay blast it before hand somtimes not that’s up to the powder coater
