drag bar question
drag bar question
pomonasporty
7 years ago
Hi Guys looking to put a set on my 09 sporty, theres heaps on ebay, but not too sure which ids the popular size etc, have searched on here but results are quite old etc, also wanting a good speedo relocation kit, any ideas?
pomonasporty
7 years ago
Thanks greeniron they look way better than stock and do give a much better stance etc!
where did you get them from/$ and did you have to mess about undoing the throttle cable etc or can you slide them off? are your cables long enough or did you put longer ones on?
Omzz48
7 years ago
That’s what I’ve got, similar to green irons just black, can’t remmeber measurements I’ll measure when I’m home tonight. But way better over standards that’s for sure :)
Omzz48
7 years ago
They’re these, 29” 1” thickness and 4” pull back. That’s from American website couldn’t find it on aussie site.
https://mstore.harley-davidson.com/store/sportster-drag-bar
