Online: paulybronco, John.R, speedzter
Stock Softail Pipes
  • arrowhead
    arrowhead
    7 years ago
    After stock pipes for 1996 Badboy springer. Had high/low pipes with crossover. Any help appreciated.
  • Oz Dan
    Oz Dan
    7 years ago
    Would a set of 2015 Softail Deluxe stock pipes fit? I’ve got a perfect set plus ac.
  • arrowhead
    arrowhead
    7 years ago
    Thanks for the reply mate. Gonna try and keep this one original though.
  • Retroman
    7 years ago
    What may slow you up with stock OEM mufflers mate is this.
    Back then , a 'Texas tune" was to knock out the central blanking plug in the muffler
    Coupled with a mild carby mod this effectively gave you a "stage 1"
    Very very few folks fitted V&H or S&S back then , so few new bike take-off mufflers on the shelf
    2001 and onwards , stock exhaust not so easily modifiable , LOADS of them to be found
    mate of mine has a 1993 Heritage Nostalgia , same HIGH/LOW system as yours.
    He has Khromewerks tapered mufflers on there , look 100% stock OEM ( but louder of course)
    His "deflowered" stock OEM mufflers lasted 1993 to 2011 ( rusted/blued) so he went Khromewerks to keep the stock look.
    He had to make a hidden bracket ( he is VERY handy that way) but the bike looks like "new"
  • arrowhead
    arrowhead
    7 years ago
    Thanks for the advice mate. Will ask a few more questions of sellers when im looking to buy. Ive hopefully sourced some original headers from Perth to keep the styling and will put something aftermarket on them for a decent sound.
    Cheers.
  • Retroman
    7 years ago
    Yes mate , Khromewerks have the 100% stock look.
    No embossing or manufacturers name stamped onto them.
    Fools PC Plod they look so "original"
