Online: B0nes, Hilly
Harley-Davidson Oil Level & Temperature Dipstick with Lighted LCD Readout - Brand NEW - 63065-09A
  • Hdsporty13
    Hdsporty13
    7 years ago
    For Sale: Harley-Davidson Oil Level & Temperature Dipstick with Lighted LCD Readout, package is opened, but dip stick never used
    Harley part number: 63065-09A
    Never used, original cost $230 asking $50 ono
    Pickup available from Thornton, NSW (Newcastle area) or can post for additional $15
    from the website:
    "New and improved "capacitive" level sensing technology provides the highest degree of accuracy and durability. These dipsticks allow you to check your oil level and oil temperature with the push of a button.
    Gloss black finish
    Oil level is indicated by a 4 segment readout - it even reminds you to check your oil when it is hot
    Designed to be waterproof, the LCD display operates on a long-lasting, replaceable lithium coin-type battery (CR2032 3V, P/N 66373-06)
    Display features a low battery indicator, and press-and-hold feature to toggle between Fahrenheit and Celsius
    Fits '06-'17 Dyna® models (except FLD). "
  • chriso
    chriso
    7 years ago
    I’ll take it, PM sent
    7 years ago
    Good one chriso, ya gotta be quick to get the bargains.
  • Hdsporty13
    Hdsporty13
    7 years ago
    This is now sold.
  • majorboot
    majorboot
    7 years ago
    Buggah, I needed one of these, the one I have is way too short. I need a longer one to reach the oil.
  • marce
    marce
    7 years ago
    i have one that i bought in 2012 for my 103, the dipstick is green and the battery needs replacing.
    i am also happy to accept $50 plus postage.
    I'm in the south west of W.A.
    marce
  • chriso
    chriso
    7 years ago
    Quoting majorboot on 03 Jul 2018 11:46 PM
    put more oil in,cheaper
  • Baloffski
    Baloffski
    7 years ago
    Quoting marce on 25 Jul 2018 10:46 AM
    marce
    I'll take that marce, 103 R.Glide.
    Go green.Have batt.
    Sending PM
  • marce
    marce
    7 years ago
    baloffski was first in with this...now sold.
    marce
  • taztiger4
    taztiger4
    6 years ago
    These things any good ?, my 110 CVO FatBob runs what I consider to be very hot & this could be a quick check
  • JFE
    JFE
    6 years ago
    Quoting taztiger4 on 20 Apr 2019 04:42 AM
    +1, out of interest. Any reviews out there?
    6 years ago
    I deliberately never bought one because they used to fail, the display that is. Probably from all the heat. They may have improved the design over the years and maybe there is now reliability but I couldn't say.
  • Jay-Dee
    Jay-Dee
    6 years ago
    Quoting JFE on 20 Apr 2019 06:15 AM
    I have one in my Breakout, about 12 - 18 months now and it seems to work ok.
  • Ratbob
    Ratbob
    6 years ago
    Yeah my CVO Fatbob does the same, it’s a trait of the bike and I’m told the 255 cam is a contributor. It pings on very hot days.
  • Grease Monkey
    Grease Monkey
    6 years ago
    Quoting Ratbob on 21 Apr 2019 07:03 AM
    Are these bikes totally stock?
  • Ratbob
    Ratbob
    6 years ago
    Quoting Grease Monkey on 21 Apr 2019 07:10 AM
    Just a more open exhaust on mine, either V&H big radius and now stock header with S&S slip ons. Same result. I was thinking of moving to SE585 with 4 degree advance key. Wadayareckon?
  • Grease Monkey
    Grease Monkey
    6 years ago
    Quoting Ratbob on 21 Apr 2019 07:22 AM
    I reckon we are hijacking this thread but 22-32 is an odd intake timing arrangement, better to pick a cam that suits your riding style that's been ground that way, some cams lend themselves to messing with + or - 4° but that one is odd to begin with.
  • taztiger4
    taztiger4
    6 years ago
    bare etc aside, mine is stock bar running SE mufflers
  • Ratbob
    Ratbob
    6 years ago
    Quoting Grease Monkey on 21 Apr 2019 08:08 AM
    Yes we’ve strayed off the thread, reckon it’s worth starting a new one?
  • Grease Monkey
    Grease Monkey
    6 years ago
    Can't hurt, bang one up in the workshop
