Online:
Widest tyre on 3 inch rim
mrjessehlee
7 years ago
Hi all!
Time for another silly question of the day that I haven't been able to get a straight answer from the dealer.. or anyone..
I am looking into modding rear end of my bike and wanted to first establish what size would be the widest tyre my 3 inch rear rim will take.
Currently it has factory 150 tyre installed.
Thank you look forward to your experience and knowledge.
mrjessehlee
7 years ago
no reply!
I will update how I went anyway, just in case someone was after the same info.
I'm happy to report 180 / 70 -16 tyre successfully replaced my factory 150 / 80 -16 tyre on 3 inch wide rim. Same tube was used.
Note, ill be fabricating my own rear fender to suit.
