Online: John.R
Front brake not working
  • flamez
    flamez
    Ok guys hears one for you
    Front brake caliper siezed up on my bike so I put a piston kit in
    Now I can not get pressure back in the brakes can't see any bubbles coming out no leaking fluid any where
    Day and a half later still the same even after I've left it over night never had this problem before ready to take up drinking again
    Just wanna ride the beast
  • Drac
    Drac
    Try bleeding it in reverse with a syringe.
    Push the fluid from the bleeder up to the master
    It will be an air bubble somewhere
  • flamez
    flamez
    The reverse bleed worked a charm thanks guys and I'm buying one of those kits
  • Retroman
    reverse bleed used to be the go with the "old" DOT 5 , no harm to paint
    If you are reverse bleeding with DOT 4 be extra super fucking careful !
    I have 2 of those pink boxed bleeder kits , well worth the wonga they are
    Still be extra super fucking careful tho'...
    I have a Mityvac and its awseome.
