Loose Rh rear turn signal stalk
  • SLIDA74
    SLIDA74
    7 years ago
    Hey peeps I have a 2000 Fatboy flstf 1450 and the Rh rear turn signal is loose..I know you need to take the strut off to tighten but I cant get this bloody Bolt off from my saddlebag support bracket?! There's a13 ml Bolt On the inside of the fender that just keeps spinning??..Please help ASAP.. Cheer's in advance
  • SLIDA74
    SLIDA74
    7 years ago
    All good peeps..sorted it out.....
