Online:
John.R
Throttle Cable Lube
Throttle Cable Lube
Benno
Had a sphincter washer cutting moment on Sunday, bloody throttle cable jammed open with a corner coming up real fast, clutch in, big revs, pulled up and got it to free up but decided to take the straightest route home. Have the housing apart now checking the cables, all looks ok but thought I would lube up the throttle and idle cables while I am in there. The service manual advises to use a couple of drops of "super oil", whats everyone using oil or WD40.
Cheers Benno
robnicko
this video below shows a good tutorial on how its done
https://www.youtube.com/watch?v=Jz1Ypua_EGY
He advises undoing the adjusters all the way and separating (around the 4 min mark) and it alleviates the need for the cable lube tool. When you see lube coming out at the throttle body end youre done
I used the silicone dry lube spray and it worked a treat.
While there give the throttle tube a clean and lube as well including the handlebar tube
rob
Benno
Awesome, thanks Brutha, how good is this forum.
Benno
Far Canal
Hmph, Cable Life lube eh?.
Have not seen that stuff before. Guess a can'd last ten lifetimes if you only serviced your own bikes.
I have just used a few drops of clean oil for mine in the past but it does seem to attract dirt when it seeps out the other end of the cable.
Wonder if any dealers ACTUALLY do that when your bike is in for a highish KLM service, for those who would not do it themselves?
Cool thread.
Ranga
I use sewing machine oil. I lubricate the cables when I fit them and that is generally good for a few years.
I put the cables about 1" up the spout of a funnel and duct tape them there, and I pull up the inner cables so they are exposed, about another of inch.
I hang the funnel on a nail in the garage wall high enough that the cables hang free and put a container under the ends of the cables. (AN old ice cream container works fine.
I then fill the funnel with sewing machine oil and leave it overnight.Next morning your cables are lubricated. All the excess oil is in the bottom container, and if you have done it properly, the outside of the cables is dry. (As taught to me by an old rider in 1977)
Hound_Dog
Syringe and ATF
binnsy
This stuff is good too and it has a tiny hollow tube as u can see for sliding perfectly into the outer cable. Got it from a pushbike shop. Worked a treat as mine was a bit sticky. Saves pulling everything apart.
fork oil....15W and flows nice. Engine oil as a backup. Its a throttle cable for goodness sake not the Enterprise! (my cable has caught on once too; it was caught up in the windscreen bracket somehow)
brucefxdl
all this discussion about lubeing things got me excited....went and did mine before next weeks trip to the murray area,omeo falls creek and brighter days.pretty simple,used a bit of 3-1 ,runs in nice.cheers
Riverina
Plus 1 on the Tri-flow.
It really is very good indeed
CL
OILLEAK2008
Easy way out for me - WD via the little red tube thingo but only when I feel it's a bit dry etc. (which is maybe every coupla years)
