Matte paint query.
  • B0GN
    B0GN
    7 years ago
    I’ve pulled the protective coat off of the rear fender of my Breakout. The one under the pillion seat, seeing as I’m only ever gonna ride solo apparently. There’s one stubborn bit of sticky left on there though. What’s the best stuff to use on the matte finish to lift it?
    Cheers in advance. Mick.
  • B0GN
    B0GN
    7 years ago
    Also, is this stuff any good? It SEEMS to work alright. But it could just be me wanting it to look better ;-)
  • graeme
    graeme
    7 years ago
    I use engine brightened on my black motor works good so that should work on a silver motor ok
  • graeme
    graeme
    7 years ago
    Should have been engine brightener
  • Vic
    Vic
    7 years ago
    be careful not to rub the matt paint too much with whatever you use.
    You'll end up with shiny spots on your matt finish.
  • Oz Dan
    Oz Dan
    7 years ago
    Eucalyptus oil gets off sticky shit with ease. Can’t see it hurting either.
  • Omzz48
    Omzz48
    7 years ago
    HD engine brightener actually works a treat! Surprised, made my engine black again
  • The_Deviant
    The_Deviant
    7 years ago
    I'll second Eucalyptus oil,  it won't hurt the Denim paint
  • B0GN
    B0GN
    7 years ago
    Thanks for the advice guys. I bought both (Wax & Grease Remover and Eucalyptus Oil). I thought I’d try the Euc oil first with it being all natural n shit. It worked a treat. A bit of gentle rubbing with a soaked cloth and it was gone in no time :-)
  • Omzz48
    Omzz48
    7 years ago
    On my old iron Id use ammonia free windex to clean the denim paint its works and is easy, quick spray and wipe it drys spotless.
