Online: John.R
softail axle washer Question
  • bloodog
    bloodog
    I have made this bracket to fit with a side plate bracket: softail rocker
    not sure witch order to use
    My question is: do I keep the washer then put on the bracket then axle nut
    or Don't use the washer just the bracket and nut
    Or bracket first washer then nut
    I will tidy it all up and seal and paint to suit
    Thanks bloodog
    That bracket looks really schetchy.  Good luck with it.
  • Baloffski
    Baloffski
    Hey Stinky ya always have to be so so succinct don ya. You are correct though.
  • STEAMER
    STEAMER
    Firstly, What is the bracket for ???
    @nd, I would make one out of Stainless, Be a hell of a lot stronger to Gal, That will break in under 1000km.
  • bloodog
    bloodog
    Thanks and I am paying attention
    I should have posted these photos also I.... WAS going to attach this to the bracket but now changing my plans
    Thanks again HDF       yufuckenknowitalls lol
  • Retroman
    Did I miss something ??
    By fugg that was as ugly as a fugly fugged thing !
    What the fugg ?
    Actually, for the Alice the bracket is way over engineered!
  • bloodog
    bloodog
    Having a nother try any help much appreciated
    This bracket aluminiun  cut down and bolt to side plate bracket ....what do you think ?
