Online: John.R
SERT Map for Andrews 57H cams needed please.
  • Ken in Cairns
    Ken in Cairns
    Well after some delay due to some personal issues, (which is why I have been pretty quite for a few months) I have finally got the bike up on the table and changed out the std cams for the Andrews 57H ones, changed out the stock needle bearings for the better Torrington style ones while I was in there, and fitted the Fueling lifters.
    Just waiting for the pushrod O-rings to arrive tomorrow to complete fitting the top end.
    I was going to re-tune the ecu with a SE585 based map, as that is the closest SE cam I could find to the Andrews, it is pretty close timing wise.
    After a looking at each map manually as the auto selection one wouldn't give me any suggestions I found Map 621SGG203.dt0.
    I intend to cut and past my AFR table into it and then do tuning runs, but if someone has a better map to start off with I would appreciate it if I could get a copy :)
    Ken
  • KB
    KB
    What bike? I've got 1 for a 110ci and 2 into 2 pipes. In any case you'd still need to dial it in correctly to suit your ride.
