Monster Ovals
  • Steve L
    Steve L
    really liking the look and sound of these mufflers. They fill the space under the bags better than the round mufflers. No need for extended bags now. A good tip for anyone with these and think they are too quiet, just knock the plugs/caps off the end of the baffles, really makes a difference.
  • Steve L
    Steve L
  • Steve L
    Steve L
    Haha all fixed now
  • Baloffski
    Baloffski
    On the money s man.You are correct.
  • Steve L
    Steve L
    Yeah mate, should only take a few minutes to do each one once mufflers are removed. Make sure you go in thru the end where you can see the cap. Don't try going in thru the clamp end of the mufflers. You need to punch it in the middle with a narrow rod or a big screwdriver as it needs to crumple a bit so it will fall out the end. No need to remove the tips either, hope that explains it for you. ??
  • killerchef
    killerchef
    explains it perfectly.  thank you steve.  will be doing this.
  • chriso
    chriso
    Got a set for sale if anyone’s wants em
