Wanted kevlar off cuts
  • bloodog
    bloodog
    Anybody know we're I can buy kevlar off cuts
    Thousands of off cuts 30mm x 30mm and larger. Not on the roll cheap off cuts
    Thanks bloodog
  • steelo
    steelo
    I’d have thought they’d be hard as to get. Everyman would be stitching them into motorbike clothing.
  • twistie
    twistie
    Hey blood. Try the up-market sail makers. The racing yachts use kevlar sails nowdays & there would be trimmings when making jibs & spinnikers
    All right ill bite.........what you going to do with them....
  • Baloffski
    Baloffski
    Now bd you may be onto something here.
    As if I have to go down the road for stuff, it takes me longer to gear up, get bike ready than to drive there. 10 minutes away from everything where I live, so consequently end up taking the bloody truck, as so much easier.
    Never worn shorts on bike in nearly 50 years of riding, but I absolutely understand where your coming from...
    Its a good idea indeed. Just a few small things, although kevlar has the ability to slow the heat transfer to your leg it also is very slow to dissipate the stored heat
  • bloodog
    bloodog
    When I have kevlar jeans I can touch the pipes and no problems
    When I were shorts althow I try but just that slight touch and yep a nother burn
    This happens mainly when parking the bike or rolling the bike from parking
  • kevinc
    kevinc
    Did you find some Kevlar? I'm looking for something to stop my arm getting burnt on the whippersnipper exhaust.
    been using one of those medical elbow joint support thingies but it is getting holes burnt in it, -no heat resistance
  • kevinc
    kevinc
     I bought a piece of kevlar fabric off ebay
    100cm x 30cm. figured i can wrap around my elbow.
