Frame stabiliser
Frame stabiliser
Steve L
anyone tried these
Steve i tried a before and after on a 2009 Ultra. Bear in mind this was just prior to the new frame we now enjoy on our tourers and the old old frames were to be nice well.....flawed! The difference was incredible. As for a modern fitment the downside i believe is more vibration thru the bike but told they wk very well.
Steve L
Thanks Paul there is usually a trade off for everything. I might give one a try to see.
A further worthwhile mod is to redo the motor mounts with some quality gear.
mickle
I know you are talking earlier bike but this didn't do a thing to stop my high speed wobbles on the 2015 CVO Limited, as mentioned the engine
mounts are supposed to go a long way to helping this problem, I fixed it in the end though by selling the bike.
Steve L
Okay thanks gents, are there any engine mounts better than others. I will get them done when I get the engine work done.
Steve L
Not on their webpage anyway. Getting Karupt Kustoms in Carrara to build the engine so will ask them what they recommend.
