sound system upgade
sound system upgade
Steve L
Hi all
been thinking about upgrading the sound on the glide. I don't want to spend much though as I have spent heaps on the suspension and engine.
Has anyone used this amp and speaker kit.
I think Odin is on the mark with his new sound system
Steve L
thanks mate, yeah I might end up with 4 speakers later but it will be a while off.
Chaser
I went with the full J&M upgrade from the US. Expensive - Yes, but well worth the investment and in independent comparisons, came out the best by far. All plug and play too.
Steve L
Yeah I know you get what you pay for but I've been spending a lot lately haha
Chaser
www.jmcorp.com
Different kits available and they will custom make a wiring harness if need be. I got this one below however I have 2 way speakers in the bagger lids and can also connect the 2 speakers when the top box goes back on, making 6 speakers. 630watt amp replaces standard amp in front fairing. All plug and play!
# XXRK-630SP4-14UL (@$1800 USD)
This is the new J&M ROKKER® XXR EXTREME Custom 630w 4-speaker/amplifier installation kit for your 2014-2018 Harley Ultra/Ultra Ltd. with the Harley BoomBox 6.5GT Premium or 4.3 standard radio.
At the very heart of this system is our in-fairing mounted 4 channel ROKKER XXRP amplifier rated @ 157.5w RMS per channel X 4 to provide up to 630w total RMS power!
The ROKKER XXR amplifier's settings have been dialed in & optimized for this exact speaker/radio configuration, to provide the on-highway volume, clarity and overall performance that most riders only dream about.
Included are J&Ms fully weatherproof 6.71" ROKKER XXR fairing & rear-pod speakers featuring a high-tech woven-fiber woofer cone & a massive high-density high-flux strength Neodymium magnet structure with large center & perimeter positioned voice coil cooling vents, to provide for maximum heat dissipation when operating at high volume levels for extended periods.
The custom designed speaker grills with mounted high-output dome tweeters are also weather-proof and shock-proof for maximum long-term durability.
This ROKKER XXR EXTREME custom installation KIT has been engineered to be 100% plug-and-play for your convenience during the installation and to maintain the complete integrity of your Harley's internal wiring harness.
The new J&M music-source test USB thumb-drive is also included for your performance comparison testing.
